A linked reporting object is an external file, cell note, or World Wide Web resource that you link to a cell in a Hyperion Essbase database. The file, note, or Web resource (indicated by a URL, or Uniform Resource Locator) can then be retrieved by the Hyperion Essbase Spreadsheet Add-in users who have access to the database.
| Note: | If your organization has licensed and implemented Hyperion Essbase Partitioning option, you can also access linked partitions from cells in Hyperion Essbase Spreadsheet Add-in. For more information on linked partitions, see Accessing Linked Partitions. |
This section describes the following procedures:
| Note: | For additional information on using linked reporting objects, see the Hyperion Essbase Spreadsheet Add-in online help. |
With the linked reporting objects feature, you can link an external file to a data cell in Hyperion Essbase Spreadsheet Add-in. Hyperion Essbase stores the file on the Hyperion Essbase server. Users who have access to the database can then retrieve the file and view the data contained in the cell.
The following example uses the Asymm.123 sample worksheet with data from the Sample Basic database. It links a sample file, Budasmp.txt, to a cell containing the Budget figure. Budasmp.txt details the budgetary assumptions for the current year.
Follow these steps to link a file to a data cell:
| Note: | You can link objects only to data cells, not to cells containing member names. |
Figure 140. Selecting a Data Cell for Linking an External File
Hyperion Essbase displays the Linked Objects Browser dialog box.
Hyperion Essbase displays the Attach Linked Object dialog box.
Figure 142. Linking a File to a Data Cell
Hyperion Essbase displays the Browse Files dialog box.
Figure 143. Selecting and Describing a File to Link
| Note: | Entering text in the File Description text box is optional. |
Hyperion Essbase copies the file to the server and establishes a link to the current data cell.
To recognize cells that have linked reporting objects attached to them, you may want to apply a visual cue, or style, to the cells.
To apply styles:
Cell D5 (the cell you just attached the linked file to) is now displayed in purple, italic font. Hyperion Essbase also refreshes the worksheet with the other options set in the Essbase Options dialog box.
Figure 144. Result of Applying a Style to a Linked Reporting Object Cell
In addition to linking external files to a data cell in Hyperion Essbase Spreadsheet Add-in, you can also link individual cell notes that contain information on particular data cells. Cell notes can have no more than 599 characters. If you need to link information to a data cell that is longer than 599 characters, you need to create and save an external file and then link the file to the data cell.
To link a cell note to a data cell:
Figure 145. Creating a Cell Note to Link
Hyperion Essbase copies the note to the server and establishes a link to the current data cell.
Now Hyperion Essbase displays two data cells (C5 and D5) in purple, italic font to represent a cell that contains a linked reporting object.
Figure 146. Result of Creating a Linked Cell Note
A URL is an address string that identifies resources on the World Wide Web, such as documents, images, and downloadable files. With the linked reporting objects feature, you can link a URL to a data cell so that users who have access to the database can link directly to the specified URL. When you access the cell from Hyperion Essbase Spreadsheet Add-in, your default Web browser opens and displays the specified URL.
| Note: | For more information on URL syntax, see the Hyperion Essbase Spreadsheet Add-in online help. |
If you have a Web browser and Internet access, follow these steps to link a data cell to the Hyperion Web site:
Figure 147. Selecting a Data Cell for Linking to a URL
Figure 148. Linking a URL to a Data Cell
Figure 149. Entering and Describing a URL to Link
| Note: | Entering text in the URL Description text box is optional. The text field for entering the URL location is limited to 512 characters. The text field for entering the URL description is limited to 80 characters. |
Hyperion Essbase copies the URL string to the server and establishes a link to the current data cell.
| Note: | The syntax for the URL is not checked at creation time; Hyperion Essbase checks the syntax when the user accesses the URL from the worksheet. The default Web browser checks for the existence (or validity) of the URL. |
Now that you have learned to create linked reporting objects, you are ready to learn how to access them from Hyperion Essbase Spreadsheet Add-in.
You have two options for accessing and editing a linked reporting object that is attached to a data cell:
| Note: | If you enable double-clicking for linked object browsing, double-clicking behavior changes for retrieving data and performing drill actions. For more information on these changes, see the Hyperion Essbase Spreadsheet Add-in online help. |
For this tutorial, you access the linked reporting objects that you created in the previous sections by using the Essbase menu item instead of the double-clicking action.
Sometimes you want to check an external file that is linked to a data cell.
To access the external file that you previously linked to a data cell:
Figure 150. Accessing a Linked External File
The Budasmp.txt file is opened from the source application.
Figure 151. Viewing the Contents of a Linked External File
| Note: | Edit the contents of a file in the source application. After the edits are made and the file saved, you can re-attach the edited file by clicking the Edit button in the Linked Objects Browser dialog box. Hyperion Essbase displays the Re-attach Linked Object dialog box, which you can use to re-attach, or relink, the edited file to the data cell. For more information, see the Hyperion Essbase Spreadsheet Add-in online help. |
Sometimes you have to edit a cell note that was previously created.
To access and edit the cell note that you previously created:
The Linked Objects Browser dialog box displays the cell note that is linked to the selected data cell.
Figure 152. Accessing a Linked Cell Note
Hyperion Essbase displays the Edit Cell Note dialog box with the selected cell note displayed.
Figure 153. Editing the Contents of a Linked Cell Note
| Note: | If you simply want to view the contents of the cell note, click the View/Launch button instead of the Edit button in the Linked Objects Browser dialog box. |
Figure 154. Result of Editing Cell Note Contents
Hyperion Essbase saves the edits to the cell note on the server.
If you followed the steps in Linking a URL to a Data Cell, you can access and edit the URL that you created.
To access the URL:
The Linked Objects Browser dialog box displays the URL that is linked to the selected data cell.
Figure 155. Accessing a Linked URL
Hyperion Essbase checks the syntax of the URL. If there are syntax errors, Hyperion Essbase displays an error message. If the URL syntax is correct, the default Web browser launches and connects to the specified site. In this case, the syntax for the URL is correct, so the default Web browser launches and connects to the Hyperion Web site.
Figure 156. Viewing a Linked URL
To edit the URL:
Hyperion Essbase displays the Edit URL dialog box with the selected URL displayed.
Figure 157. Preparing to Edit the Contents of a Linked URL
Figure 158. Editing the Contents of a Linked URL
Hyperion Essbase saves the edits to the URL on the server.
The Web browser launches and connects to the new URL.
Figure 159. Viewing an Edited URL
