OLAP Spreadsheet Add-in User's Guide for 1-2-3
Hyperion Essbase supports simultaneous access to multiple databases.
The databases can be in different applications and can be stored on different
servers. In Lotus 1-2-3, you can open multiple worksheets, each of
which can be connected to a different database. An individual worksheet
can access only one database at a time. Use the Connect command from
the Essbase menu to switch the connection between databases.
| Note: | Depending on the status of production applications at your site, you may not
have access to additional applications or databases. Check with the
Hyperion Essbase system administrator if you need access to other
applications.
For this tutorial, you do not need to connect to another database.
To access multiple databases, use the following procedure:
- Select Essbase > Connect.
- In the Essbase System Login dialog box, select the server you
want to access from the Server list box (or type in the name of the
server).
- Press Tab to move to the Username text box and type your
username.
- Press Tab to move to the Password text box and type your
password.
- Click OK to connect to the server.
When the server connection is complete, a list of available application and
database pairs appears in the Application/Database list.
- Double-click the Application/Database pair that you want to connect to in
the Application/Database list. Alternatively, you can select the
Application/Database pair and click OK.
If the application is not already running, Hyperion Essbase automatically
starts it. There may be a brief pause as the application loads;
the time required to start an application depends on number of databases, the
sizes of the databases, and the sizes of the indexes of the databases
contained within the application.
- Open a new worksheet and repeat the steps to connect to additional
databases. You can open one database at a time per worksheet.
For information on connecting to multiple
databases from Hyperion Essbase Query Designer, refer to An Advanced Hyperion Essbase Tutorial.
If you frequently connect to multiple databases, you may need to check the
active database for each worksheet. There are two ways to view the
database connection status:
- The Style tab of the Essbase Options dialog box contains a Connection
Information text box. This box displays connection information for the
active worksheet.
- The Hyperion Essbase Disconnect dialog box lists all active worksheets and
their connection information. This dialog box also enables you to
disconnect one or more worksheets from their respective databases.
[ Top of Page | Previous Page | Next Page ]
