Linked partitions are part of the Hyperion Essbase Partitioning product. They provide the ability to link Hyperion Essbase databases that contain different dimensions without losing access to all dimensions of both databases. If your organization has purchased and implemented the partitioning product, you can take advantage of its powerful capabilities. The Hyperion Essbase Database Administrator's Guide describes how to design and implement a linked partition. Hyperion Essbase Application Designer usually sets up partitioning.
You can set visual cues, or styles, for cells tagged as linked objects. These cells are access points to the linked partition within the linked database. You have two options for accessing a linked partition from a data cell in Hyperion Essbase Spreadsheet Add-in:
If you enable double-clicking for linked object browsing, double-clicking behavior changes for retrieving data and performing drill actions. For more information on these changes, see the Hyperion Essbase Spreadsheet Add-in online help.
When you select Essbase > Linked Objects from a linked partition cell, Hyperion Essbase completes the following actions:
| Note: | The Linked Objects Browser dialog box may also contain a list of linked reporting objects, such as cell notes and external files. For more information, see Using Linked Reporting Objects. |
| Note: | Hyperion Essbase does not preserve formulas across partitions. |
You can now perform operations such as drill down and drill up to get more information on the new worksheet.
| Note: | The Sample Basic database that you are using for this tutorial does not contain a linked partition. |
If the Hyperion Essbase application designer has a linked partition set
up, use the following procedure to access the linked partition in Hyperion
Hyperion Essbase creates a new worksheet that contains the dimensions and members for the cell in the linked partition. |
