Before you begin the advanced tutorial, complete the steps in the next two sections, Connecting to a Database and Setting Hyperion Essbase Options. In addition, be sure to read Following Guidelines During the Tutorial and Reviewing the Sample Basic Database for important information about what you should expect as you perform the tutorial steps.
To access Hyperion Essbase data for the advanced tutorial, first connect to the Sample Basic database on the server. This tutorial assumes that you have the appropriate privileges to connect to a server, an application, and a database.
Hyperion Essbase displays the Essbase System Login dialog box.
Figure 83. Essbase System Login Dialog Box
| Note: | To complete the steps that follow, you need to know the name of the Hyperion Essbase server, your username, and your password. If you do not have this information, contact the Hyperion Essbase system administrator. |
| Note: | You can change your password when you are connected to a server. See Changing a Password. |
Hyperion Essbase displays a list of available application/database pairs in the list box. A Hyperion Essbase server allows simultaneous access to multiple applications. An application can contain multiple databases. Only the databases to which you have security access appear in the list.
For this tutorial, you use the Sample Basic database. If the Sample Basic database was installed as part of the Hyperion Essbase installation, it is shown in the list. If Sample Basic is not shown in the Application/Database list, ask the Hyperion Essbase system administrator to install it.
Figure 84. Available Application and Database Pairs
If the application is not already running, Hyperion Essbase automatically starts it. There may be a brief pause as the application loads; the time required to start an application depends on the number of databases, the sizes of the databases, and the sizes of the indexes of the databases that are contained within the applications.
Before you begin the tutorial, make sure that the worksheet options are set to the initial settings shown in the figures in this section.
| Note: | For information on each option in the Essbase Options dialog box, see the Hyperion Essbase Spreadsheet Add-in online help. |
Figure 85. Initial Settings for Display Options
Figure 86. Initial Settings for Zoom Options
Figure 87. Initial Settings for Mode Options
Figure 88. Initial Settings for Global Options
| Note: | The settings in the Essbase Options dialog box may change as you access the various sample Lotus 1-2-3 files as part of the tutorial. Leave the settings as they are unless the tutorial advises you to change them. If you have different option settings, the illustrations presented in this chapter may not match the worksheet view. |
