Essbase supports simultaneous access to multiple databases.
The databases can be in different applications and can be stored on different
servers. In Lotus 1-2-3, you can open multiple worksheets, each of
which can be connected to a different database. An individual worksheet
can access only one database at a time. Use the Connect command from
the Essbase menu to switch the connection between databases.
- Note:
- Depending on the status of production applications at your site, you may not
have access to additional applications or databases. Check with the
Essbase system administrator if you need access to other applications.
For this tutorial, you do not need to connect to another database.
- Note:
- Tasks that you should not perform as part of the tutorial are
shown in light colored boxes.
To access multiple databases, use the following procedure:
- Select Essbase > Connect.
- In the Essbase System Login dialog box, select the server you
want to access from the Server list box (or type in the name of the
server).
- Press Tab to move to the Username text box and type
your username.
- Press Tab to move to the Password text box and type
your password.
- Click OK to connect to the server.
When the server connection is complete, a list of available application and
database pairs is displayed in the Application/Database
list.
- Double-click the Application/Database pair that you want to
connect to in the Application/Database list. Alternatively,
you can select the Application/Database pair and click
OK.
If the application is not already running, Essbase automatically starts
it. There may be a brief pause as the application loads; the time
required to start an application depends on number of databases, the sizes of
the databases, and the sizes of the indexes of the databases contained within
the application.
- Open a new worksheet and repeat the steps to connect to additional
databases. You can open one database at a time per worksheet.
For information on connecting to multiple databases from Essbase Query
Designer, refer to "A Basic Essbase Tutorial".
If you frequently connect to multiple databases, you may need to check the
active database for each worksheet. There are two ways to view the
database connection status:
- The Style tab of the Essbase Options dialog box contains a Connection
Information
text box. This box displays connection information for the active
worksheet.
- The Essbase Disconnect dialog box lists all active worksheets and their
connection information. This dialog box also enables you to disconnect
one or more worksheets from their respective databases.
