When you add Essbase Spreadsheet Add-in to Lotus 1-2-3, most Lotus 1-2-3 operations remain unchanged; Essbase Spreadsheet Add-in simply adds a new menu, a Essbase toolbar, and mouse shortcuts with which you can access the Essbase server.
The tasks described in this tutorial are basic tasks. That is, these are tasks that you probably use often when working with Essbase. An Advanced Essbase Tutorial describes more advanced tasks. This tutorial chapter contains the following sections:
The examples used in this tutorial are based on the sample database (called Sample Basic) that is included with the Essbase installation. Contact the Essbase system administrator for information about accessing the Sample Basic database or about accessing other databases on the Essbase server.
