Accessing Linked Partitions
Linked partitions are part of the Essbase Partitioning product. They provide the ability to link Essbase databases that contain different dimensions without losing access to all dimensions of both databases. If your organization has purchased and implemented the partitioning product, you can take advantage of its powerful capabilities. The Database Administrator's Guide describes how to design and implement a linked partition. The Essbase application designer usually sets up partitioning.
Note:
The Partitioning product also enables the Essbase application designer to set up transparent or remote partitions. For more information on partitioning, see the Database Administrator's Guide.
You can set visual cues, or styles, for cells tagged as linked objects. These cells are access points to the linked partition within the linked database. You have two options for accessing a linked partition from a data cell in Essbase Spreadsheet Add-in:
When you select Essbase > Linked Objects from a linked partition cell, Hyperion Essbase completes the following actions:
You can now perform operations such as drill down and drill up to get more information on the new worksheet.
Note:
The Sample Basic database that you are using for this tutorial does not contain a linked partition. Tasks that you should not perform as part of the tutorial are shown in light colored boxes.
To access a linked partition in Essbase Spreadsheet Add-in if the Essbase application designer has a linked partition set up:
  1. Locate a linked object cell, as indicated by the style applied to the cell.
  2. Select Essbase > Linked Objects to open the Linked Objects Browser dialog box.
    Note:
    Alternatively, select the Enable Linked Object Browsing check box in the Essbase Options dialog box to enable double-clicking to view linked objects.
  3. Select the partition that you want to connect to and click View/Launch.
    Linked Objects Browser Dialog Box, Linked Partition
Essbase creates a new worksheet that contains the dimensions and members for the cell in the linked partition.
Note:
You need to have the proper privileges to access a linked partition. If your user account and password match the account information for the linked partition, Essbase establishes a connection with the linked partition. Otherwise, Essbase displays the Essbase System Login dialog box for you to enter the user account and password information manually.
