Getting Acquainted with Essbase Spreadsheet Add-in
This section provides the following information to help you get acquainted with Essbase Spreadsheet Add-in:
Adding Essbase Spreadsheet Add-in
If you manually update your environment settings or if you have removed Essbase Spreadsheet Add-in from the Lotus 1-2-3 environment, you must use the Lotus 1-2-3 facility to add Essbase Spreadsheet Add-in into Lotus 1-2-3. The facility adds the Essbase menu to the Lotus 1-2-3 menu bar and points Lotus 1-2-3 to the Essbase Spreadsheet Add-in file in the \Essbase\bin directory. This file is on the hard drive of your PC, if that is where you installed Essbase Spreadsheet Add-in, or on the network drive if that is where you set up your PC operating environment to run Essbase Spreadsheet Add-in.
To add Essbase Spreadsheet Add-in to Lotus 1-2-3:
  1. In Lotus 1-2-3, select File > Add-Ins > Manage Add-Ins.
    Lotus 1-2-3 displays the Manage Add-ins dialog box.
  2. Click Register and select the file ESS123.12A in the \Essbase\bin directory where you installed Hyperion Essbase Spreadsheet Add-in on your PC hard drive (if you installed the Add-in software there), or in the bin directory where the Hyperion Essbase system administrator installed the Hyperion Essbase Spreadsheet Add-in on a network drive (if you set up the PC operating environment to run the Add-in software there).
  3. Click Open and select the ESS123.12A add-in file. Make sure there is a check mark next to the add-in file.
    Figure 4. Manage Add-ins Dialog Box
  4. Click Done to close the Manage Add-ins dialog box and start the Hyperion Essbase Spreadsheet Add-in.
    The Essbase startup screen is displayed.
    If you do not see the Essbase startup screen or if your system does not list the Essbase Spreadsheet Add-in menu options, see the Installation Guide for troubleshooting information.
Starting Essbase Spreadsheet Add-in
Because Essbase Spreadsheet Add-in software for Lotus 1-2-3 is implemented as a Lotus 1-2-3 add-in, you must start Lotus 1-2-3 from Windows to use Essbase Spreadsheet Add-in software.
You must open a worksheet before attempting to connect to the Hyperion Essbase server. An attempt to connect to theHyperion Essbase server without opening a worksheet results in an error message.
To begin an Essbase session:
  1. Start Lotus 1-2-3.
    After the Lotus 1-2-3 startup screen disappears, the Essbase startup screen is displayed.
    The Hyperion Essbase menu should be displayed in the Lotus 1-2-3 menu bar. If you do not see the Hyperion Essbase menu, you may need to use the Lotus 1-2-3add-in facility to add Essbase Spreadsheet Add-in into Lotus 1-2-3. For more information, see "Adding Essbase Spreadsheet Add-in".
  2. From the Lotus 1-2-3 menu bar, select Essbase to open the menu.
    Figure 5. The Essbase Menu
    Note:
    If the Lotus 1-2-3 status bar is not displayed, you can display it by selecting View > Show Status Bar.
Accessing Online Help
Essbase Spreadsheet Add-in includes a context-sensitive online help system. You access the Essbase Spreadsheet Add-in online help in one of three ways. Which way you choose depends on the type of information that you need,
Enabling Mouse Actions
The following terms are used throughout this guide to describe mouse operations:
Essbase offers enhanced mouse actions in Lotus 1-2-3. You can use the mouse to do any of the following:
To enable double-clicking to retrieve, drill down, and drill up on Essbase data:
  1. Select Essbase > Options.
  2. In the Essbase Options dialog box, select the Global tab.
  3. Select the Enable Double-Clicking check box.
    When the Enable Double-Clicking check box is selected, you can retrieve and drill down to more detailed data (primary mouse button) and drill up to less detailed data (secondary mouse button). When the double-clicking option is enabled, the Lotus 1-2-3 in-cell editing feature is overridden.
    Figure 7. Essbase Options Dialog Box--Global Tab
  4. Click OK to return to the worksheet.
For information about setting the primary mouse button to display the Linked Objects Browser dialog box when you double-click a data cell, see the Essbase Spreadsheet Add-in online help.
