Saving and Disconnecting
After performing basic retrieval, navigation, and formatting tasks, you can save worksheets and disconnect from Essbase. This section instructs you in the following procedures:
Saving a Worksheet
At any point during the Essbase session, you can save the active worksheet with the Lotus 1-2-3 commands, File > Save or File > Save As. Thus, you can keep a personal library of database views. You can open the worksheet during a later session and retrieve the latest data values to update the view.
Note:
Saving a worksheet saves the settings from the Essbase Options dialog box unless the worksheet is protected. Essbase cannot save option settings for a protected worksheet.
Disconnecting from Essbase
When you finish retrieving and navigating through data, disconnect from the Essbase server to free up a port (or user count) on the server for other Essbase Spreadsheet Add-in users.
To disconnect from the server:
  1. Select Essbase > Disconnect.
    Essbase displays the Essbase Disconnect dialog box, where you can disconnect any worksheet that is connected to a database.
    Figure 81. Essbase Disconnect Dialog Box
  2. From the list, select a worksheet name, and then click Disconnect.
  3. Repeat Step 2 until you have disconnected all active sheets.
  4. Click Close to close the Essbase Disconnect dialog box.
Note:
You can also disconnect from the server by simply closing Lotus 1-2-3. An abnormal termination of a Lotus 1-2-3 session, such as a power loss or system failure, does not disconnect your server connection.
Logging Off
Essbase provides two administrative facilities that control user connections:
For further information, contact the Essbase system administrator.
