The main sections of this guide are structured as tutorials that take you
step-by-step through basic and advanced tasks in Essbase Spreadsheet
Add-in. This document contains the following information:
- "Introducing Release 6.5" provides information on migrating from previous versions of
Essbase to Release 6.5 and lists all new features and
enhancements.
- Introducing Essbase introduces you to basic concepts of retrieving and
manipulating data through the spreadsheet interface.
- A Basic Essbase Tutorial provides a step-by-step tutorial of basic data navigation,
ad hoc retrieval, and reporting techniques.
- An Advanced Essbase Tutorial describes advanced reporting and retrieval techniques for
users that need special reports or formatted data views.
- Using Drill-Through provides a brief overview of the Essbase Integration
Services drill-through product.
- The Index contains a list of terms and their page numbers. Select
or look up an index entry to view the page to which the entry refers.
- Note:
- The Essbase Spreadsheet Add-in online help provides a comprehensive section
on Essbase Spreadsheet Toolkit. This section enables you to customize
and automate your use of Essbase by using Lotus 1-2-3 macros and Visual Basic
for Applications (VBA) functions. For more information on the Essbase
Spreadsheet Add-in online help, see "Accessing Online Help".
The Spreadsheet Add-in User's Guide for Lotus
1-2-3 is provided in the ibm\db2olap\docs\pdf directory
in .pdf format for online viewing and printing in Adobe
Acrobat Reader (Release 3.0.1 or higher). The
.pdf file is named Ess123w.pdf. You
can download Adobe Acrobat Reader from the Essbase CD-ROM or from
http://www.adobe.com. On the Essbase
CD-ROM, the Acrobat Reader executable file is located in the Adobe directory
under the appropriate platform and language-version subdirectories. To
install Adobe Acrobat Reader, launch the executable file, follow the prompts,
and provide the information requested.
