Data values are changed frequently in applications that involve planning, budgeting, and forecasting. After you retrieve data into the worksheet, you can use Hyperion Essbase Spreadsheet Add-in to change values, enter formulas, and format data. Hyperion Essbase is also designed to permit multiuser, concurrent database access and update. Depending on your security privileges, you may be able to modify all data values or a certain subset of values. To recognize cells to which you have read/write access, apply a visual cue, or style, to the cells. For more information, see Applying Styles to Data Cells. To update data from a worksheet, you must lock the database area that contains the values that you want to change. Locking prohibits other users from changing the data that you want to update. Other users can retrieve locked data but cannot lock or change the data. You have exclusive update rights to that area.
| Note: | You cannot update attribute-related data on the server because attribute data is always calculated dynamically and, hence, is not saved. |
You can lock data values in three ways:
| Note: | The Retrieve & Lock command is not supported with Dynamic Time Series members. |
To update the server with data values from the worksheet, use the Send command on the Hyperion Essbase menu. After updating the server, the Send command automatically unlocks data (unless you are in Update Mode). You must disable Update Mode to stop locking blocks automatically.
You can unlock data blocks in two ways:
P&l.123, a sample Lotus 1-2-3 file installed as part of the default Hyperion Essbase installation, illustrates how to update data on the server.
To view the P&l.123 worksheet:
Hyperion Essbase retrieves data and locks the appropriate area of the database.
Figure 160. P&L Worksheet After Retrieve & Lock
Hyperion Essbase changes the affected data values.
Hyperion Essbase updates the server and unlocks the data blocks.
Figure 161. P&L Worksheet After Sending New Values to the Server
| Note: | Hyperion Essbase provides a worksheet update logging facility that tracks and logs all data updates sent from Hyperion Essbase Spreadsheet Add-in to the server. The Hyperion Essbase system administrator enables this facility for extra protection against data loss. For more information, see the Hyperion Essbase Database Administrator's Guide or contact the Hyperion Essbase system administrator. |
