When you finish using drill-through, disconnect from the Essbase server to
free up a port on the server for other Essbase Spreadsheet Add-in
users.
To disconnect from the server:
- Select Essbase > Disconnect.
Essbase displays the Essbase Disconnect dialog box, where you
can disconnect any spreadsheet that is connected to a database.
Figure 206. Essbase Disconnect Dialog Box
- Note:
- Essbase may return an error message when you attempt to disconnect after
using drill-through. If an error message is returned, select Essbase
> Retrieve from the sheet and then disconnect.
- Select a sheet name from the list and click
Disconnect.
- Repeat Step 2 until you have disconnected from all active sheets.
- Click Close to close the Essbase Disconnect dialog
box.
- Note:
- You can also disconnect from the server by closing Lotus 1-2-3. An
abnormal termination of a Lotus 1-2-3 session, such as a power loss or system
failure, does not disconnect your server connection.
