Using Drill-Through
Drill-through consists of the following tasks:
The following sections describe each of these tasks and step you through a live working drill-through session.
Accessing Drill-Through from the Spreadsheet
From Essbase Spreadsheet Add-in, you can access detail-level drill-through reports that are based on the member intersections of Essbase data cells in the sheet. Each drill-through report has been predefined by an administrator at your organization; that is, each drill-through report is already set up to retrieve specific columns from the relational source, to sort data in these columns in specific ways, and so forth. Using the Drill-Through Wizard, you can customize these predefined drill-through reports to retrieve only the data you want, displayed in a specific way.
To access the predefined drill-through report, double-click a drill-through cell in the spreadsheet (or select a range of cells and select Essbase > Linked Objects). You can set styles for cells tagged as drill-through to help identify which cells in the sheet are associated with drill-through reports. When you double-click a drill-through cell, Essbase displays the Linked Objects Browser dialog box, which displays an drill-through report entry. A single cell can have multiple reports associated with it. The Linked Objects Browser dialog box also displays entries for linked partitions and other linked object types, such as cell notes, URLs, and application files. After you view or customize the drill-through report, Essbase Integration Services retrieves data from the relational source and displays the results in a new spreadsheet.
Before starting the drill-through tutorial, perform the following tasks:
  1. Open a sample Lotus 1-2-3 file that contains the appropriate member intersections from the sample database for the drill-through report. This file, Essdt.123, is provided as part of the default Essbase installation.
  2. Set a style for data cells that are associated with drill-through reports.
To access the sample file and sample database:
  1. Start Lotus 1-2-3.
  2. Select File > Open and open the Essdt.123 file from the Essbase\client\sample directory.
    The sample file should look like the following screen. Note that the Market Detail tab is selected in this example. The default tab that is selected when you first open the file may be different.
    Figure 180. Sample Lotus 1-2-3 File for Drill-Through
    The sample file shows data for specific members of an Essbase database. This sample file contains the following three predefined drill-through reports, indicated by the tabs of the spreadsheet: "Market Detail," "Measures Detail," and "Product Detail." Using drill-through, you can access these reports and customize them so that Essbase Integration Services retrieves only the data you need and displays it in the desired format.
  3. Select the Market Detail tab on the spreadsheet.
  4. Select Essbase > Connect and connect to the appropriate sample database.
    Note:
    A specific sample database for drill-through is not automatically provided with Essbase Integration Services. For information on the sample database, contact the person at your organization who installs Essbase Integration Services to set up a database for you.
  5. Select Essbase > Options and select the Style tab.
  6. In the Data Cells option group, select the Integration Server Drill-Through check box and click Format.
    Essbase displays the Font dialog box.
  7. Select Bold Italic from the Font style list box.
  8. Select Blue from the Color drop-down list, and click OK to return to the Essbase Options dialog box.
    Figure 181. Font Dialog Box Selection
    Note:
    In the Essbase Options dialog box, Essbase displays an example of the selected style in the Sample box.
    The following screen shows how the Essbase Options Style tab looks with the style for drill-through cells defined:
    Figure 182. Sample Style for Drill-Through Data Cells
  9. In the Essbase Options dialog box, select the Display tab, and then select the Use Styles check box.
    Figure 183. Setting the Use Styles Option
  10. Click OK to close the Essbase Options dialog box.
  11. Select Essbase > Retrieve to display the new style in the spreadsheet.
    In Figure Figure 184, the sample drill-through report is associated with the data cells for Actual, Profit, and Product at the month and Eastern state levels, so that these data cells are displayed in blue, bold, italic font.
    Figure 184. Sample Lotus 1-2-3 File with Drill-Through Style Applied
To access the sample drill-through report from Essbase Spreadsheet Add-in:
  1. Select any drill-through cell; for example, cell G4.
    Figure 185. Selecting a Drill-Through Cell
    Note:
    You can also select a continuous range of cells in the sheet to display all drill-through reports associated with cells you select. In this example, we have only one drill-through report attached to the range of cells.
  2. Select Essbase > Linked Objects to open the Linked Objects Browser dialog box.
    Alternatively, select the Enable Linked Object Browsing check box in the Essbase Options dialog box (Global tab), which enables you to double-click a linked object cell to open the Linked Objects Browser dialog box. This option works only with single-cell selection. If you select a range of cells, use the Essbase > Linked Objects menu command.
    Figure 186. Linked Objects Browser Dialog Box with Drill-Through Entry Selected
  3. Select the drill-through report entry and click View/Launch.
  4. In the Select Drill-Through Report dialog box, select Market detail and click Execute.
    The results of the drill-through report are displayed in a spreadsheet.The results of the Market Detail report shows that the regional director for the East region is John West and that the population for New York is between 18,000,001-21,000,000.
    Figure 187. Results of Market Detail Drill-Through Report
    Note:
    If there is only one report available for the cells you select in the spreadsheet, and if that report is not designed to be customized, drill-through generates the report and immediately displays the results in the spreadsheet. The person at your organization who develops drill-through reports specifies whether you can customize a report and whether you need to log in to drill-through and the relational data source.
  5. Follow the steps in the next section, "Selecting Drill-Through Reports to View or Customize" to select a report to customize.
After you launch drill-through from the Linked Objects Browser dialog box, Essbase Integration Services displays the Select Drill-Through Report dialog box under the following conditions:
The Select Drill-Through Report dialog box displays the list of drill-through reports available for the cells you select in the spreadsheet. Depending on how a report is defined in Integration Services Console, you may have access only to view, not customize, the report.
Note:
Tasks that you should not perform as part of the tutorial are shown in light colored boxes.
The sample report used for this tutorial is the Measures Detail report. You will use the Drill-Through Wizard to customize this sample report. To execute a predefined drill-through report without customizing it, perform these tasks:
  1. Select the report that you want to view from the Available Reports list box.
  2. Click Execute.
Essbase Integration Services retrieves the data from the relational source and displays the results in a new spreadsheet. The new sheet is added before the current sheet.
To customize the sample drill-through report:
  1. In Essdt.123, select the Measures Detail tab.
  2. Select Essbase > Connect and connect to the appropriate sample database.
    Note:
  3. Select Essbase > Options and select the Style tab to define styles for this sheet.
  4. In the Data Cells option group, select the Integration Server Drill-Through check box and click Format.
    Note:
    The style for drill-through cells may already be set as blue, bold, italic font because you set the style in the previous exercise. If this is the case, then go to Step 7.
  5. Select Bold Italic from the Font style list box.
  6. Select Blue from the Color drop-down list, and click OK to return to the Essbase Options dialog box.
    Figure 188. Font Dialog Box Selection
    Note:
    Figure 189. Sample Style for Drill-Through Data Cells
  7. In the Essbase Options dialog box, select the Display tab and select the Use Styles check box.
    Figure 190. Setting the Use Styles Option
  8. Click OK to close the Essbase Options dialog box.
  9. Select Essbase > Retrieve to display the new style in the spreadsheet.
    In this example, the sample drill-through report is associated with every member intersection at the state level in the East region, so that all data cells associated with an Eastern state and children of Cola are now displayed in blue, bold, italic font.
    Figure 191. Sample File with Drill-Through Style Applied
To access the sample drill-through report from the Essbase Spreadsheet Add-in:
  1. Select any drill-through cell; for example, cell G6.
    Figure 192. Selecting the Drill-Through Cell for the Measures Detail Report
    Note:
    If Essbase Integration Services is not running, drill-through does not launch properly. For more information, contact the Essbase system administrator.
    Note:
    If you are prompted with the Drill-Through Login dialog box to connect to Essbase Integration Services and the relational data source, enter the appropriate connection information. The person at your organization who administers Essbase Integration Services and develops drill-through reports should provide you with this information.
    Figure 193. Linked Objects Browser Dialog Box with Drill-Through Entry Selected
    The Select Drill Through Report dialog box is displayed.
    Note:
    In the Select Drill Through Report dialog box, if the Customize button is selectable, then you can customize the report. If more than one drill-through report is displayed, then you can select from the different drill-through reports. In this tutorial, only one report, "Measures detail," is displayed and customizable.
  4. Select the Measures detail report from the Available Reports list box.
    Figure 194. Selecting the Sample Drill-Through Report
  5. Click Customize.
    Note:
    The Customize button may be selectable or not selectable for any given report, depending on how the report was defined in Integration Services Console.
    Essbase Integration Services displays the first screen of the Drill-Through Wizard.
    Figure 195. Drill-Through Wizard Dialog Box, Introductory Screen
  6. Click Next to display the Select Columns and Display Order dialog box.
    Figure 196. Select Columns and Display Order Dialog Box
  7. Follow the steps in the next section, "Selecting and Ordering Columns", to select and order rows for the customized report.
Using the Drill-Through Wizard, you can customize predefined drill-through reports. The first task in the Drill-Through Wizard is selecting and ordering columns to retrieve from the relational database. These columns contain detailed information that is not available in the Essbase database.
In the Select Columns and Display Order dialog box, you can select which columns you want Essbase Integration Services to retrieve from the relational data source. From this dialog box, you can also specify how the columns are displayed in the resulting report.
The Available Columns list box displays a list of columns available from the relational data source for this report (as defined in Integration Services Console). The Selected Columns list box displays the columns from the Available Columns list box in expanded form. You can remove columns from the Selected Columns list box to exclude them from the drill-through report.
In this example, the columns from the Available Columns list box are selected for inclusion in the sample Measures detail report. These columns are displayed in expanded form in the Selected Columns list box.
To remove one of the selected columns from the drill-through report:
  1. In the Selected Columns list box, select the MARKET.STATE column.
    Note:
    To select multiple columns in the list that are not adjacent to each other, hold down the Ctrl key and select each column. To select a range of columns, hold down the Shift key and click the first and last columns in the list, which also selects all columns in between them.
    Figure 197. Selecting Columns to Remove From the Drill-Through Report
  2. Click to move the selected column from the Selected Columns list box back to the Available Columns list box.
    Note:
    To move a column from one list box to another, click or . To move all columns from one list box to another, click or .
  3. Click Next to display the Select Data Sort Order dialog box, and follow the steps in the following section, "Ordering Data" to further customize the report.
    Note:
    When you finish customizing the report, click Finish at any time to generate the report and view the results in a new sheet. The new sheet is placed before the current sheet.
Ordering Data
In the Select Data Sort Order dialog box, you can select an ascending or descending sort order for the data in a column. Sort order determines the order in which rows will be displayed in the drill-through report. For example, you can sort the contents of the Time.TRANSDATE column, which represents the transaction dates, in ascending order in the drill-through report.
To define the sort order of rows in the drill-through report:
  1. In the Available Columns list box, select the Time.TRANSDATE column.
    The columns in the Available Columns list box are those that you selected in "Selecting and Ordering Columns". The columns in the Column list box are those for which a sort order has already been defined in Integration Services Console.
    If a data sort order was selected when the report was created in Essbase Integration Services Console, the Order By list box displays that selection. Otherwise, the default sort order is Ascending.
  2. Click to move the Time.TRANSDATE column to the Column list box so that you can define a sort order for the column.
    Note:
    Figure 198. Moving a Column to the Column List Box for Sorting
  3. In the Column list box, double-click the Time.TRANSDATE column to change the data sort order from Ascending to Descending so that transaction date values are displayed in reverse chronological order in the drill-through report.
    Figure 199. Selecting the Data Sort Order
  4. Click Next to display the Select Data Filters dialog box, and follow the steps in the following section, Filtering Data to further customize the report.
    Note:
    Tasks that you should not perform as part of the tutorial are shown in light-shaded boxes.
To change the data sort order for multiple columns at one time, perform these tasks:
  1. Hold down the Ctrl key and select the desired columns from the Column list box.
  2. Click Order By.
    Essbase Integration Services displays the Order By dialog box.
    Order By Dialog Box
  3. Select Ascending or Descending and click OK to return to the Selecting Data Sort Order dialog box.
Filtering Data
You can apply filters to determine what Essbase Integration Services retrieves for the drill-through report. For any given column, you may want to retrieve only data that meets certain conditions. For example, the MEASURES.CHILD column in the sample database contains all children of the Measures dimension. In the sample drill-through report, if you did not apply a filter to this list of measures, Essbase Integration Services would retrieve all children from the relational source, because the sample drill-through report applies to all children of Measures. In this section, you will apply a filter to the MEASURES.CHILD column so that all children of Measures, except Misc, are included in the report.
Note:
When you apply a filter on a non-level 0 member using Essbase Integration Services, the filter may return more members than expected. To work around this problem, use the Drill-Through Wizard.
To define a filter:
  1. Select the MEASURES.CHILD column from the Column list box.
    The columns in the Column list box are those that you selected in "Selecting and Ordering Columns".
    Figure 200. Select Data Filters Dialog Box
    Note:
    If there is a filter already attached to the column, it is displayed in the Condition list box. The full string of the filter is displayed in the lower Condition text box.
  2. With the MEASURES.CHILD column selected, click Add.
    The Set Filter on Column dialog box is displayed.
    Figure 201. Set Filter on Column Dialog Box
  3. Select CHILD from the Column drop-down list box.
    The column displayed in the Column drop-down list box is the one that you selected in "Filtering Data".
  4. Select the < > operator, which represents not equal to, from the Operator drop-down list box.
    Note:
    You can select multiple values at one time only if you have selected In or Not In as the filter operator. For more information on filter operators, see the Drill-Through online help.
  5. Click the Browse button to open the Select Filter Values from the List dialog box, which lists all possible values for that column.
    The Select Filter Values from the List dialog box is displayed.
    Note:
    Essbase Integration Services retrieves these values directly from the relational data source. If the relational data source contains many values, Essbase Integration Services confirms if you want to view them all before it retrieves them from the data source.
  6. In the Select Filter Values from the List dialog box, select Misc and click OK. The Set Filter On Column dialog box is displayed.
    Figure 202. Selecting Filter Values from the List
  7. Click Add to add the condition to the Filters list box.
    Note:
    For information on using multiple filter conditions, see the Integration Server Drill-Through online help.
    The Set Filter on Column dialog box should now look like Figure Figure 203:
    Figure 203. Defining a Filter for a Column
    The filter defined above causes all children of Measures, except Misc data, to show in the drill-through report.
    Note:
    The Add button becomes unselectable after creating the first filter, but becomes selectable when you create another filter. In this tutorial, you are creating only one filter. The And and Or options are used when combining multiple filters. The default value is Or, which means that Essbase Integration Services applies the filter if any of the conditions you specify are met. If you select And, Essbase Integration Services applies the filter only if all the conditions are met.
  8. Click OK to return to the Select Data Filters dialog box. Notice that the filter defined in the Set Filter on Column dialog box is displayed in the Condition list box and text box of the Select Data Filters dialog box.
    Figure 204. Result of Defining a Filter for a Column
    Note:
    You can also create a filter by typing the filter conditions directly into the Filters list box of the Set Filter on Column dialog box. For more information, see the Drill-Through online help.
    To delete a filter, select the filter and click Clear. To delete all filters, click Clear All.
  9. Click Finish.
    Essbase Integration Services generates the customized drill-through report and displays the results in a new spreadsheet. The new spreadsheet is added to the workbook before the current spreadsheet.
    Figure 205. Customized Drill-Through Report
In this sample, the customized drill-through report reflects the specifications that you set using the Drill-Through Wizard:
