Disconnecting from Essbase
When you finish using drill-through, disconnect from the Essbase server to free up a port on the server for other Essbase Spreadsheet Add-in users.
To disconnect from the server:
  1. Select Essbase > Disconnect.
    Essbase displays the Essbase Disconnect dialog box, where you can disconnect any spreadsheet that is connected to a database.
    Figure 207. Essbase Disconnect Dialog Box
    Note:
    Essbase may return an error message when you attempt to disconnect after using drill-through. If an error message is returned, select Essbase > Retrieve from the sheet and then disconnect.
  2. Select a sheet name from the list and click Disconnect.
  3. Repeat Step 2 until you have disconnected from all active sheets.
  4. Click Close to close the Essbase Disconnect dialog box.
    Note:
    You can also disconnect from the server by closing Lotus 1-2-3. An abnormal termination of a Lotus 1-2-3 session, such as a power loss or system failure, does not disconnect your server connection.
