Working with Currency Conversions
Organizations with offices in different countries generally do business in the currency of the host country (known as the local currency). Such organizations must convert data entered in local currencies to a common currency for consolidation and analysis.
The Essbase Currency Conversion product can be purchased separately for Essbase. If your organization has purchased this product and has implemented a currency conversion application, you can take advantage of the powerful capabilities of Hyperion Essbase Currency Conversion. The Database Administrator's Guide describes how to design and implement a currency conversion application.
The following sections provide a brief tutorial for working with currency conversions:
Retrieving Currency Conversion Data
This section focuses on basic currency conversion concepts, including the easy-to-use Currency Report command.
A currency conversion application consists of two databases:
Apply exchange rates from the currency rates database to local values from the main database to derive converted values. The Essbase server product installation includes a sample currency conversion application (installation options) that consists of two sample databases: a main database called Interntl and a currency rates database called Xchgrate.
The Sample Interntl database consists of five dimensions: Year, Measures, Product, Market, and Scenario. All but the Market and Scenario dimensions are identical to the Sample Basic database. The Market dimension includes Toronto, Vancouver, Montreal, France, Germany, Spain, and the UK. The Scenario dimension handles different currency types (such as Actual and Budget) in both local and converted currencies. In this database, all local currencies are converted to the common currency of U.S. dollars.
The Sample Xchgrate database, which is a subset of the main database, contains four dimensions:
Connecting to the Sample Currency Databases
To complete the following exercises, the Sample Interntl and Sample Xchgrate databases must be installed on the server. Contact the Essbase system administrator if these application and database pairs are unavailable.
To retrieve data from the Sample Interntl database:
  1. Select Essbase > Connect.
  2. Select the Sample Interntl database and click OK to complete the connection.
    The Essbase installation also includes sample Lotus 1-2-3 files that illustrate currency conversion concepts.
  3. From the \Essbase\client\sample directory, open Local.123.
    The worksheet contains actual (Act) and budget (Bud) data entered in local currencies for New York and Germany.
    Figure 167. Retrieving Local Data
  4. From the \Essbase\client\sample directory, open Convert.123.
  5. Select Essbase > Retrieve.
    The worksheet contains values for Actual and Budget as they display after conversion.
    Figure 168. Retrieving Converted Data Values
    Notice that the worksheet contains data that is converted to U.S. dollars. Values for New York remain the same, but Germany values are converted. Essbase converts the values by using the exchange rates from the Sample Xchgrate database.
  6. From the \Essbase\client\sample directory, open Rates.123. Connect to the Sample Xchgrate database.
  7. Select Essbase > Retrieve.
    Figure 169. Retrieving Exchange Rates from a Currency Database
The worksheet contains all possible combinations of exchange rate scenarios, categories, and types by month. Because this example converts to U.S. dollars (US$), the sample file contains a base rate of 1 for US$. Therefore, the local and converted figures remain the same for New York. Essbase converts the figures for Germany, however, by using data values in the currency database, as follows:
Note:
A conversion can be defined as a multiplication or division operation on exchange rates. The definition is determined by the application designer.
Performing Ad Hoc Currency Reporting
A main database, such as Sample Interntl, usually contains values that are converted and stored in the database. You may want to perform currency conversions dynamically, as well. Essbase provides this capability with the Currency Report command. This command enables you to interactively change the currency rates and types applied to the retrieval.
To perform an ad hoc conversion on data in the Convert.123 file:
  1. From the \Essbase\client\sample directory, open Convert.123.
    The worksheet contains data that is already converted to U.S. dollars.
  2. Select Essbase > Connect and connect to the Sample Interntl database.
  3. Select Essbase > Retrieve.
  4. Select Essbase > Currency Report.
    Essbase displays the Essbase Currency Report dialog box.
    Figure 170. Essbase Currency Report Dialog Box
    The Essbase Currency Report dialog box enables you to interactively modify the exchange rates applied to the retrieval. The box contains options for currency settings, names, categories, and years. For more information on these options, see the Essbase Spreadsheet Add-in online help.
    Note:
    The dimension names CurName, CurType, and CurCategory are default names for a currency database. The application designer can use different names for any of these dimensions.
  5. Select the currency settings that you want to apply.
    For example, select CN$ from the CurName list box and Bud xchg from the CurType list box.
  6. Click Apply to apply the settings.
  7. Select Essbase > Retrieve to refresh the data in the worksheet with the results of the ad hoc conversion.
    Figure 171. Performing an Ad Hoc Currency Conversion
    Essbase converts the New York and Germany figures to Canadian dollars (CN$).
  8. Click the Clear button in the Essbase Currency Report dialog box to disable currency reporting and return to standard retrieval mode.
    Note:
    Performing a currency report retrieval does not change values in the database. It simply performs a temporary conversion as part of the retrieval. Converted data values may not always balance, because the ad hoc conversion is performed on values that were previously calculated or previously consolidated in another currency.
If values must balance and verify, they must be converted to the target currency in the database, calculated, and retrieved. This procedure differs from the ad hoc currency conversion retrievals described in this section; see the Essbase system administrator for more information.
