When you finish using Drill-Through, disconnect from the Hyperion Essbase server to free up a port on the server for other Hyperion Essbase Spreadsheet Add-in users.
To disconnect from the server:
Hyperion Essbase displays the Essbase Disconnect dialog box, where you can disconnect any sheet that is connected to a database.
Figure 199. Essbase Disconnect Dialog Box
| Note: | Hyperion Essbase may return an error message when you attempt to disconnect after using Drill-Through. If an error message is returned, choose Essbase > Retrieve from the sheet and then disconnect. |
| Note: | You can also disconnect from the server by closing Lotus 1-2-3. An abnormal termination of an Lotus 1-2-3 session, such as a power loss or system failure, does not disconnect your server connection. |
